file Having an issue with some plugins
9 years 7 months ago #4470 by dattard21
Replied by dattard21 on topic Having an issue with some plugins
Hey Olivier, so I switched off the minification as a first step, but it's looking I'm having some issues with the Paypal donate button. Would you be able to figure out what the problem is now?
9 years 7 months ago #4471 by syw
Replied by syw on topic Having an issue with some plugins
Hello David,
the donate button seems to be working now, I do not see any issue with it at this point.
When I click on 'donate', it does take me to the PayPal page, as I think it is intended.
9 years 7 months ago #4472 by dattard21
Well now, I'll need to start switching stuff back on ... because I turned off all minification :|
9 years 7 months ago #4473 by syw
Beware that this may undo what jQuery Easy has fixed...
Before switching everything back on, you should check what the jQuery Easy plugin has fixed (through the plugin report tool) so that if the minimization software cannot work in conjunction with jQuery Easy, you try and fix those issues manually, knowing what happened in the background.
9 years 7 months ago #4474 by dattard21
I did try to fix what I saw in the report Olivier - I unloaded the scripts which were getting removed.
Funnily enough the donate plugin still seems not to work well unless I actually login with Super User credentials to the front end and actually see the report.
When this is switched off and I log out, the donate still does not work.
Minification is still off ... so I really can't figure it out :S
9 years 7 months ago #4475 by syw
I would suggest you contact support for that extension and request help from them.
The thing is, I am able to get to the PayPal page once in a while, even though I have no Super User privileges and not showing any report. The console does not give me enough information to find out what is wrong and the jQuery Easy plugin seems to do its job.
