file Error tooltip
10 years 1 month ago #4323 by mbndiaye
Error tooltip was created by mbndiaye
Hi !
Someone can help me. I've got this error "Uncaught TypeError: $(...).tooltip is not a function" in frontediting.js and shortcodes.js.
I use Joomla 3.4.3. I've installed Easy profile but i don't know how to do for solving the problem.
I 'm in emergency.
Thanks.
10 years 1 month ago #4324 by admin
Replied by admin on topic Error tooltip
in jQuery Easy Profiles, you need to create a module instance that will be assigned to all your menu items (I suspect this problem is site-wide). In the module, enable jQuery, select the jQuery version coming with the framework. That should be enough to re-order your javascript libraries.
10 years 1 month ago #4325 by mbndiaye
Replied by mbndiaye on topic Error tooltip
Hi !
Sorry but I don't know how create a module and do what you toold.
I'm new in Jquery.
Have you an example please
10 years 1 month ago #4326 by admin
No problem.
When you buy jQuery Easy Profiles, you need to enable the plugin and create module instances (like you create any other module in Joomla, nothing to do with jQuery at this point - in the module manager, click on 'new' and select jQuery Easy Profiles). If you have not done so, I strongly recommend you download the documentation that definitely will help you further.
The following user(s) said Thank You: mbndiaye
