file Wrong path for jquerynoconflict.js
10 years 7 months ago #4047 by PJMFD
Wrong path for jquerynoconflict.js was created by PJMFD
I have noticed that the path generated for adding the no conflict script is :
/plugins/system/jqueryeasy/jquerynoconflict.js
When on my server it should be:
/plugins/system/jqueryeasyprofiles/jquerynoconflict.js
Where do I go to make the change?
Many Thanks
Peter
10 years 7 months ago #4048 by admin
Replied by admin on topic Wrong path for jquerynoconflict.js
Hello Peter,
you uncovered a bug! Indeed the path is wrong.
I will issue a fix later today.
In the meantime, you can use the Joomla version of the noconflict code (by selecting 'Joomla System' for the jQuery version) or add the no conflict code through script declaration or, if you can dig into the code, go into plugins/system/jqueryeasyprofiles/jqueryeasyprofiles.php line 286 and make the change.
Thank you for pointing this one out!
10 years 7 months ago #4049 by PJMFD
Replied by PJMFD on topic Wrong path for jquerynoconflict.js
Hi Olivier
Glad to help - in a small way!
Nice easy fix for me to do this end.
Great tool too.
Many Thanks
Peter
10 years 7 months ago #4050 by admin
No problem Peter, thank you again and thank you for your support! I have released the fix but if you digged into the code, no need to download it.
