file Slider Widgetkit problems jquery?
10 years 9 months ago #3929 by justinjibi
Slider Widgetkit problems jquery? was created by justinjibi
i've made a website and i cant resolve the issue.On frontpage, I have a slider widgetkit yootheme and a dp calendar google. When the website loads the first time, i have the images from the slider under each other, what is not correct. When i make a refresh its OK.
Ive tried so many times to resolve the problem, but no succes.(also with jquery easy, what i dont know)
It seems that the jquery is loaded many times and so the images from the slider are not loaded correctly.
Here is the site
web799.webbox666.server-home.org/
You are my last chance.
Please help
Best regards
Patrick
10 years 9 months ago #3931 by admin
Replied by admin on topic Slider Widgetkit problems jquery?
Hello Patrick,
it seems like you figured it out, I don't see anymore error now that you are using the plugin!
10 years 9 months ago #3932 by justinjibi
Replied by justinjibi on topic Slider Widgetkit problems jquery?
Have you maybe an idea, what i can do, that the images of the slider loads normal and not under each other? As i said, in Firefox i see the problem when the page load the first time, when i make a refresh, all is ok? Bizarre
10 years 9 months ago #3933 by admin
I have no idea, I opened the page on Firefox and it worked fine from the start.
You may have a problem with the cache. Empty your browser's cache and try again.
But all worked fine on my end and there is no error in the console.
