file jQuery Easy profiles not working.
11 years 4 weeks ago #3723 by ehrereich
jQuery Easy profiles not working. was created by ehrereich
I've been using jQuery Easy for quite a while. I decided to go with jQuery Easy Profiles. The package successfully installed but the plugin is not working properly.
11 years 3 weeks ago #3725 by admin
Replied by admin on topic jQuery Easy profiles not working.
it seems to be working the way it should according to the screenshot you provided.
The thing is, it does work through modules instances, the settings are not set through the plugin in this case.
I suggest you download the documentation in order to understand the slight differences there are compared to jQuery Easy. You will find jQuery Easy Profiles much more flexible and will be able to use different configurations on the same website in order to suit your needs.
The following user(s) said Thank You: ehrereich
