file Template/Component issue
11 years 2 months ago #3678 by carterkoths
Template/Component issue was created by carterkoths
A key component is conflicting with a recently installed template. Can jQuery help to resolve the issue?
11 years 2 months ago #3679 by admin
Replied by admin on topic Template/Component issue
If it is a jQuery-related issue, chances are the plugin may be able to fix it indeed.
11 years 2 months ago #3680 by carterkoths
Replied by carterkoths on topic Template/Component issue
I installed jQuery and when I go to the plugin there is nothing on the right hand side of the screen.
11 years 2 months ago #3681 by carterkoths
Please see attached screen shot.
11 years 2 months ago #3682 by admin
I have tempted to reproduce your issue but without success.
Have you tried re-installing the plugin? Is this the only component that shows that behavior?
There are no visible errors so you may find errors if you set the system debug to 'yes' in the global configuration.
