file jquery easy prof not loaded
11 years 3 months ago #3645 by leondelyon
jquery easy prof not loaded was created by leondelyon
Hi there,
using Joomla v3.3.0 & jquery easy profile v1.0.0.
I want to set it running on all web pages so I set the wildcard * in the enable on pages parameter
set v1.11 with sub version 0. Plugin is enable.
Didn't see anything in the source code of the page in relation with jqueryeasy:
<script src="http://localhost/components/com_community/assets/joms.jquery-1.8.1.min.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/script-1.2.min.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/stream.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/window-1.0.min.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/minitip-1.0.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/bootstrap/bootstrap.min.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/jqueryui/datepicker/js/jquery-ui-1.9.2.custom.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/jqueryui/datepicker/js/jquery-ui-timepicker-addon.min.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/joms.ajax.min.js" type="text/javascript">
<script src="http://localhost/components/com_community/assets/pickadate/picker.combined.js" type="text/javascript">
<script src="/media/jui/js/jquery.min.js" type="text/javascript"></script>
<script src="/media/jui/js/jquery-noconflict.js" type="text/javascript"></script>
<script src="/media/jui/js/jquery-migrate.min.js" type="text/javascript"></script>
<script src="/plugins/system/t3/base/bootstrap/js/bootstrap.js" type="text/javascript"></script>
<script src="/media/tooltips/js/script.min.js" type="text/javascript"></script>
<script src="/plugins/system/t3/base/js/jquery.tap.min.js" type="text/javascript"></script>
<script src="/plugins/system/t3/base/js/off-canvas.js" type="text/javascript"></script>
<script src="/plugins/system/t3/base/js/script.js" type="text/javascript"></script>
<script src="/plugins/system/t3/base/js/menu.js" type="text/javascript"></script>
<script src="/plugins/system/t3/base/js/responsive.js" type="text/javascript"></script>
Did I miss something ?
Any clue ?
Cheers,
L
11 years 3 months ago #3646 by admin
Replied by admin on topic jquery easy prof not loaded
for jQuery Easy to work on all pages, you do not need to set anything in the 'enable in pages'.
Let me know if that fixes your problem.
Also, in the plugin, set to show the error report.
11 years 3 months ago #3648 by leondelyon
Replied by leondelyon on topic jquery easy prof not loaded
unfortunately not. We've set plugin with report display on, module jquery only for v1.11.0, other parameters set as default, didn't change them.
Still nothing in relation with, in the source code of the web page. I probably miss something. Would you mind to have a look on our live site at www.coeursdebreizh.net just in case of something obvious we've missed.
Cheers,
L
11 years 3 months ago #3650 by admin
Did you enable the plugin? (sorry, that seems obvious but it is easy to forget).
Otherwise, send your credentials (login/pwd) to [email protected] so I can take a look at your configuration. Thank you!
11 years 3 months ago #3651 by admin
After looking at the administration page, it turns out the module was missing the position.
