file Some assistance on setup please
11 years 8 months ago - 11 years 8 months ago #3468 by admin
Replied by admin on topic Re: Some assistance on setup please
This is good support, indeed.
Ok, I took another look at your site, specifically the page test.9thsword.org/members-only/event-cal...t-event/36-new-event
Now, in the jQuery Easy plugin:
in the basic settings:
- select the jQuery version 1.9 and set sub-version to 1
- download the migrate script (to make sure the old scripts work with jQuery 1.10.2 (go to: code.jquery.com/jquery-migrate-1.2.1.min.js)
- copy the script to your server in the 'libraries' folder (I suggest under a jquery folder, if none exists)
- add the script path to the 'Migrate local path' field in the jQuery Easy plugin
in the advanced settings:
- add the next 2 lines to the 'strip remaining scripts' parameter
http://test.9thsword.org/components/com_rseventspro/assets/js/jquery/jquery-1.9.1.js?v=5
http://test.9thsword.org/components/com_rseventspro/assets/js/jquery/jquery.noconflict.js?v=5
Once done, please get back to me and I will assess the situation from there.
Last edit: 11 years 8 months ago by admin.
11 years 8 months ago #3469 by PaladinBrewer
Replied by PaladinBrewer on topic Re: Some assistance on setup please
Hey buddy havent heard from you in a while. I dont know if you've taken a look at it yet, but Ive kept it as is. Of course since my site is really broken now I cant do any work on it until I know you're done looking :D
11 years 8 months ago #3470 by admin
I guess you have not read my last post dated 3 days ago then lol. I did not forget about you indeed. I have even been contacted by the RSEventPro developer...
11 years 8 months ago #3471 by PaladinBrewer
Uh oh, some coding drama. Well let me know when you can please so I can get some website work done. As much as I almost don't want to :(
11 years 8 months ago #3472 by admin
I am waiting on you, you need to follow my instructions from 4 days ago #3468
11 years 8 months ago #3473 by PaladinBrewer
Oh I did do that, that's why my website isn't showing up correctly anymore. I'm sorry I thought I had already responded to you many days ago telling you I had done it. Perhaps I forgot to hit the Submit button or something :(
