file Background Color website
11 years 10 months ago #3312 by JoopL
Background Color website was created by JoopL
Since a few weeks I use jQuery Easy. This is necessary for the module Raxó. After installing Easy jQuery show that the entire background of my website has received. Gray background Normally that is white with the left and right columns in a different color. Now everything became gray. It does not matter if I have Raxo are on or off. How do I get the background in the original state? Or probably transparent? Further work jQuery Easy and Raxo perfectly. Only the background color is the problem.
My website is: www.genderen.org
Sincerely, Joop.
11 years 10 months ago #3314 by admin
Replied by admin on topic Re: Background Color website
Hi Joop,
there are errors on your page.
$(document).ready(function(){
generates an error because colliding with MooTools.
Try and set the jQuery Easy advanced parameter 'Fix Document Ready' to 'yes'.
Get back to me when this is done :-)
11 years 10 months ago #3315 by JoopL
Replied by JoopL on topic Re: Background Color website
You are great! I spent days sitting tinkering to find the problem! And then a simple act sufficient to solve it. You can admire my website with the new setting: www.genderen.org.
Thanks a lot and now I can enjoy even more of the perfect pugin!
Regards, Joop from Netherlands. Sorry I do the translation by Google.
11 years 10 months ago #3316 by admin
Wonderful! Works great now :-)
Greetings from Chicago!
11 years 10 months ago #3317 by JoopL
Is there an diffrent from free and prof. software?
Thanks a lot for helping me!! :P
11 years 10 months ago #3318 by admin
jQuery Easy is only offered as free software. There is no commercial version and it will remain that way :-)
There is just a small fee for support.
