file JQuery is not defined
11 years 11 months ago #3301 by rodiusd
JQuery is not defined was created by rodiusd
got following error:
ReferenceError: jQuery is not defined
jQuery(document).ready(function() {
Had this already working but had to reinstall.
So believe that I'm missing a setting and can't find it? Can someone help out?
Installattion Joomla3.1.5/JQuery Easy 1.5.2
11 years 11 months ago #3302 by admin
Replied by admin on topic Re: JQuery is not defined
you need to enable 'jQuery' or 'jQuery + jQuery UI' and set the jQuery version in order for the plugin to add jQuery. Make sure you have the sub-version if you are using recent versions of the jQuery library.
It seems like you have no jQuery on the page or a wrong path to the library (which could happen if you forgot to set the sub-version number on jQuery 1.9 for instance or a wrong path to a local file).
