file Easydiscuss issue
12 years 5 days ago #3126 by ismaelhaider
Easydiscuss issue was created by ismaelhaider
Hi team, I there is issue with Komento, so uninstalled it, now all are working except Easydiscuss Component, after click in easydiscuss menu, Again,Menu and Button for"Submit question" not working, can you help me plz
swiftqatar.com/component/easydiscuss/ask...ized.html?Itemid=563
12 years 5 days ago #3127 by admin
Replied by admin on topic Re: Easydiscuss issue
your template minimises all scripts therefore jQuery Easy has no effect on them (if you are using jQuery Easy that is).
You have one too many jQuery library loading.
Try disabling minimisation in your template and see if the jQuery Easy plugin helps fix your issues.
Note that jQuery Easy does not handle the library Dojo at this time.
