file Slideshow doesn't work any more
12 years 1 week ago - 12 years 1 week ago #3035 by admin
Replied by admin on topic Re: Slideshow doesn't work any more
Hello again,
if using jQuery Easy, your jQuery version should be 1.7, not 1.5 (since it is supposed to replace a line from your code where jQuery is 1.7.1).
It seems like, as far as I can tell, that your template is not taking MooTools into account at all, which is a mistake since a lot of the Joomla! functionality (like forms for contacts) use MooTools.
Please contact your template's provider and see with them how you can include MooTools into their template.
I do add MooTools in my templates by adding the line:
/* The following line loads the MooTools JavaScript Library */
JHtml::_('behavior.framework', true);
into the index.php file since MooTools is already included in the Joomla! framework.
Last edit: 12 years 1 week ago by admin.
The following user(s) said Thank You: mengana
12 years 1 week ago #3076 by mengana
Replied by mengana on topic Re: Slideshow doesn't work any more
Hi, I've been looking for jQuery Easy version 1.7 but I cannot find such a version unter joomla extensions....
I've found something like Easy Slider 17... Is that what I need?
12 years 1 week ago #3078 by admin
I was talking about the jQuery library, not the jQuery Easy plugin. In jQuery Easy (the plugin), set jQuery (the library) to version 1.7.
That is what I meant :-)
12 years 1 week ago #3081 by mengana
I've found this one:
extensions.joomla.org/extensions/core-en...bGlicmFyeSI7fQ%3D%3D
but it is version 1.0.2
12 years 1 week ago #3082 by mengana
Hi, I'm completely desperate! my client had just communicated that the drop down menu doesn't work either!!! What can i do? The template provider refuses to give a solution to my problem...
I need these Mootools in my template but I don't know how to added. Everything worked properly since I've updated a stupid booking component (the provider from this stupid component doesn't answer either!!! Is there a component or plugin or i don't know what that installs the Mootools in the tamplate?
I would be very grateful for every help!
12 years 1 week ago #3086 by mengana
Hi! I could solve the problem with the menu: I've installed a Mootools Enabler/Disabler (phproberto-plg_sys_mootable-51e2c97.zip) and now it works. The only problem is still the slideshow. Unfortunately I cannot find for the template in use a button enable/disable Mootools or something like that... I'm just thinking about including just an animated .gif with all the images in my slide!!!!
Any typ will be welcome!
And thank you again for your support!
