file JQuery Easy - if enabled Website not shown
12 years 2 weeks ago #2978 by lexspecial
JQuery Easy - if enabled Website not shown was created by lexspecial
hello,
i just bought the JQuery Easy Plugin, but if its enabled the website is not shown.
No matter wich Jquery Version i pick in Backend, if its enabled i get Error 500 and my Page is not reachable.
Does someone know what the Problem could be?
I need the plugin working because another Plugin is not working without it.
12 years 2 weeks ago #2986 by admin
if you bought the plugin, somebody screw you up. Please let me know.
Can you post screenshots of the options you have selected in the plugin? Are you using the options by default and only changing the jQuery version? If so, your site should show with errors at the worst, but not a 500 error. You may have conflicts with another component that works on your site's template (SEO tool, admin tool, tool or template that compresses javascript...). Do you have such a tool enabled or template options that would minimize scripts?
