file Bug (typo?) in code
14 years 2 weeks ago #271 by who8
Bug (typo?) in code was created by who8
hi,
Thanks for this plugin. It works great after a minor change. I think there's a bug although I'm not sure if it's intentional or not.
In jqueryeasy.php line 207 you have
$body =  preg_replace("/(^[\r\n]*|[\r\n]+)[\s\t]*[\r\n\']+/", "\n", $body);
while the original regex (I found it here programming-oneliners.blogspot.com/2006/...ty-lines-php-29.html) is
preg_replace("/(^[\r\n]*|[\r\n]+)[\s\t]*[\r\n]+/", "\n", $string);
That extra quote that you're replacing is causing code in Joomlart templates to break, because this
var megamenu = new jaMegaMenuMoo ('ja-megamenu', {
  'bgopacity': 0,
  'delayHide': 300,
  'slide'    : 0,
  'fading'   : 0,
  'direction': 'down',
  'action'   : 'mouseover',
  'tips'     : false,
  'duration' : 300,
  'hidestyle': 'fastwhenshow'
is replaced with this
bgopacity': 0,
delayHide': 300,
slide'    : 0,
fading'   : 0,
direction': 'down',
tips'     : false,
duration' : 300,
Removing the quote or commenting out the line entirely fixed it for me.
14 years 1 week ago #273 by admin
Replied by admin on topic Re: Bug (typo?) in code
I apologize for the late reply, I have been sick.
Thank you so much for sharing this, I probably have been a little overzealous in my regular expression.
It is a bug and I will issue a fix as soon as possible to benefit other users of your findings.
