file I read Nothing But great reviews
12 years 1 month ago #2627 by adrianboogaard
I read Nothing But great reviews was created by adrianboogaard
I am using Widget Kit from yoothemes and Sobipro. Both site say this plugin resolves the issue. "widget kit does not show on sobi pages".
So as a total newbie and having no idea of what to do I am at the mercy of this forum. All post I read on this issue say just install an GO. Well that does not seem to work.
I have the plugin enabled but am scared to change settings. I am hoping some one could help me out.
the site is www.adsetra.com on the main page there are three widgetkits working together with no issue (The TOP LARGEST BANNER, ADSETRA HOT DAILY DEALS and in the bottom "Business Card Showcase"
When I go to a Sobipage : example
www.adsetra.com/index.php?option=com_sobipro&sid=2&Itemid=225
there should be 2 instanses of widget kit
(The TOP LARGEST BANNER and in the bottom "Business Card Showcase")
The module seems to be there but no slideshow. As I think but no absolutley NOTHING this is a conflict.
Any help would be very wonderful!
Very Best Regards,
Adrian
12 years 1 month ago #2628 by admin
Replied by admin on topic Re: I read Nothing But great reviews
Hello Adrian,
I am not sure the plugins which are supposed to work with jQuery are ready for v1.10. Most likely they work well with v1.8. Also, do you really need jQuery UI?
Make the version changes and see if that makes any difference.
12 years 1 month ago #2629 by adrianboogaard
Replied by adrianboogaard on topic Re: I read Nothing But great reviews
Hey Olivier,
Thank you soooo much for your fast response,
I must mention I do not know much!
As for your question "do you really need jQuery UI" I do not know.
I have set "Basic Site Options" to:
Enable jQuery to jQuery
Version is set to 1.8(latest version)
Sub-Version is Empty
Saved settings.
No visual change
I just wanted to say thank you, no one can ever help me with jquery issues, and for some reason I always run into them!
Adrian
12 years 1 month ago #2630 by admin
No problem :-)
There is actually an issue. It seems like your template compresses javascript, therefore there is already a jQuery library loaded in it that cannot be visible to jQuery Easy. Look into the template settings and disable it. Give it a try :-)
12 years 1 month ago #2631 by admin
And/or disable jQuery in your template if you can.
12 years 1 month ago #2632 by adrianboogaard
Hey Olivier,
I did not find anything with disable jquery in my template manager, however i did find this in SobiPro settings and turn it off. (See Image 1).
It is kinda working now!
If you search the following customer you will see a blue icon of movie and coin and folder. When I used to click on these I would get a pop-up. now I just get that they open new page instead of pop-up.
Like I said before, I think this could be related but I know NOTHING.
