file ReferenceError: jQuery is not defined
12 years 1 month ago #2616 by JohnneyBoy
ReferenceError: jQuery is not defined was created by JohnneyBoy
Just installed jQuery Easy 1.5.2, enabled it only On JQuery.
It seems the slideshow that was working is not :(
There is also an error in the console saying 'ReferenceError: jQuery is not defined' in file '<hostname>/plugins/system/jqueryeasy/jquerynoconflict.js
This seems a tad odd, as I would have expected jQuery easy to have loaded jQuery ...
Any pointers plz?
John
12 years 1 month ago #2621 by admin
Replied by admin on topic Re: ReferenceError: jQuery is not defined
Hi John,
usually the answer is in the source code... You can also look at the report created by the plugin. Set it in the 'other' options. That will give you an idea of what is going on.
If jQuery is not loaded, it may come from the fact that it does not find your local jQuery library file (wrong path) or that you use a version of jQuery from Google and forgot to specify the sub-version number (for 1.9 and up).
