question-circle sobipro
13 years 5 months ago #261 by angel
sobipro was created by angel
Hi, I have a problem with the jquery conflict in sobipro, I use yootheme and sobipro and two scripts run at the same time so I try to use your plugin but I need some help por configure the plugin, I tried several options but nothing.
galice.net/es/info-util/ventas-y-alquile...359-Piso-Ferrol-220m
I put the theme smoothness
I don't know what is needed to do with the other options
thanks a lot :)
13 years 5 months ago #262 by admin
Replied by admin on topic Re: sobipro
it seems like everything is set up right (as far as jQuery Easy is concerned).You still have a version of jQuery you need to get rid of. Go to the advanced part of the plugin and add '/cache/template/gzip.php?jquery-f8baf168.js' to the list of remaining scripts to clean out.
The following user(s) said Thank You: angel
13 years 5 months ago #263 by angel
Replied by angel on topic Re: sobipro
Thanks for take a look :)
I put this line with the www.galice.net
or only the part you send me?? sorry i not sure
13 years 5 months ago #264 by admin
The part I have sent you should be enough. Just make sure it is gone by looking at the <head> section of your website.
