file Issues with slideshow with Chrome
12 years 2 months ago #2533 by mggonzalez
Issues with slideshow with Chrome was created by mggonzalez
Hello
Olivier, please know that your work is much appreciated!
It fixed the issues I was having with Virtuemart, however, it kinda messed up the front-page slideshow, where one picture is overlapping the other.
This is the log:
re-ordered header libraries
removed var $j = jQuery.noConflict();
removed 1 jquery-noconflict.js script(s)
removed 2 jQuery library(ies)
added the jQuery library ajax.googleapis.com/ajax/libs/jquery/1.8/jquery.min.jsadded the script /plugins/system/jqueryeasy/jquerynoconflict.js
removed 3 empty script tag(s)
Execution time (in seconds): 0.0314736366272
Do you have a suggestion?
12 years 2 months ago - 12 years 2 months ago #2535 by admin
Replied by admin on topic Re: Issues with slideshow with Chrome
Hello, thanks for the compliment :-)
There is not much I can predict from the error report, although you may need to re-inject the line var $j = jQuery.noConflict(); that your code probably needs (use the field 'script declaration'). You may also try disabling the noconflict removals altogether, that may do the trick.
Last edit: 12 years 2 months ago by admin.
12 years 2 months ago #2538 by mggonzalez
Replied by mggonzalez on topic Re: Issues with slideshow with Chrome
That did the trick!!! Merci beaucoup!! Vous êtes le meilleur!
12 years 2 months ago #2540 by admin
Wonderful et merci :-)
