file Help with jQuery and my site
12 years 2 months ago #2530 by bcorcodilos
Help with jQuery and my site was created by bcorcodilos
My website seems to be working perfectly on all browsers except Safari and the iPhone. I know the extension can help, I am just unsure about what settings need to be fixed. My website is www.tortillaflatsavalon.com
Any help would be really appreciated!
Thanks,
Brian Corcodilos
12 years 2 months ago #2531 by admin
Replied by admin on topic Re: Help with jQuery and my site
Hello Brian,
first, I want to congratulate you on a beautiful site. It really looks great!
I don't see anything striking so far other than you are using a version of jQuery (1.5) which is outdated and you may have components that will not react the way you want with that version. Make sure K2, the carousel (and Bootstrap!) and other extensions work well with the version of jQuery you selected in jQuery Easy.
Try also: do not have the plugin set the noconflict script. It seems like all libraries have their own noconflict script embedded already (but I am not sure 100%, since I have not seen the site before using the plugin).
Can you also be more specific on what is not working on Safari and iPhone? Narrow down what does not work and make sure the extensions you installed are actually compatible with Apple browsers.
