file Conflicts with other modules, even after uninstall
13 years 5 months ago #253 by ran1mal
hi and thank you for making a useful and free extension. I hear from others that it has been a life-saver. Unfortunately I wasn't able to resolve the issue I was having so I uninstalled it but now several of my other modules are not working.
Specifically the two modules no longer working are:
Stocks GK4 - Parsing XML error...
Ultimate Feed Display - : Call to a member function enable_cache() on a non-object...
Would JQ Easy have removed/altered some essential code and left it that way even after uninstallation? I apologize if this is outside the scope of the support you mean to provide. I am a bit lost as to what may have happened.
My site: www.calcom.co
if you are able to take a look, let me know if you need anything else to diagnose the issue. My only thought so far is that it is related to "enabling cache" on both modules.
13 years 5 months ago - 13 years 5 months ago #254 by admin
I am sorry about all the trouble you are having.
jQuery Easy only removes scripts and stylesheets associated with jQuery 'on the fly' (at the creation of a page on the server) and does not affect any code if disabled or uninstalled. There is no caching or backed up code.
Your problem lies somewhere else I am afraid. Look into the cache options you have suggested. I don't have enough information/access to the code to look any further. I would suggest you contact the developers for the modules in fault.
Good luck!
Last edit: 13 years 5 months ago by admin.
13 years 5 months ago #255 by ran1mal
I appreciate you taking a look. Thanks for your time
