file Struggling to get it to work.
13 years 7 months ago #25 by phill1111
Struggling to get it to work. was created by phill1111
Can you see any reason why the plugin doesn't help here - www.windsurf.me.uk/cpg133
The dropdown menu's of the main Joomla navigation fail on this page using a bridged version of coppermine gallery. The gallery scrip uses jQ 1.3.2.
13 years 7 months ago #29 by admin
Replied by admin on topic Re: Struggling to get it to work.
You may have library conflicts. You still have more than one jQuery library loaded in the page.
jQuery Easy does not work in all cases. It all depends on how other components handle the loading of jQuery. Try to see if you have an option to disable jQuery from the Coppermine Photo Gallery.
I would also suggest you make sure that the jQuery Easy plugin is the last plugin that loads in the page (re-order your plugins).
13 years 7 months ago #30 by phill1111
Replied by phill1111 on topic Re: Struggling to get it to work.
Cannot disable jQ in Coppermine. As a member of the development team of it I really should put some effort into learning jQuery :lol: . I never really got to grips with it.
Moving it down the list doesn't work. Oh well, it was worth a go. I will be updating the site soon from J1.5 to J2.5 so I will concentrate my efforts when that is done in a few months. Thanks for taking the time to look and thanks for a great plugin that I am sure will help many.
13 years 7 months ago #31 by admin
Sorry it did not work out for you. Yes, this plugin helped a lot of people, but not for a few cases. Most of the time, it is because jQuery is embedded in an extension, the javascript needs to be updated to be usable with jQuery.noConflict() and/or the jQuery version selected in jQuery Easy is not compatible... I any case, it needs some work and it is rather difficult if you are not familiar with jQuery.
