file JQEASY_JQLIB & JQEASY_JQNOCONFLICT errors
12 years 9 months ago #2496 by admin
Thanks Robert for the feedback.
I will look at it as soon as I have some available time.
12 years 9 months ago #2514 by Robert G
Replied by Robert G on topic Re: JQEASY_JQLIB & JQEASY_JQNOCONFLICT errors
Hello again Olivier,
More news. Seems -- for my minimal use of the plugin -- that JCH_Optimize was not causing the problem. The BT_Login Module has an option for loading jQuery which I had enabled before installing your plugin and JCH_Optimize. Turning "load jQuery" off in the Login Module has fixed my problem.
Robert
12 years 9 months ago #2515 by admin
Thanks Robert.
Interesting... Even with jQuery enabled in that module, that should not break jQuery Easy. Unless there is something not done right here. I will download that module and see why this breaks jQuery Easy.
Thanks so much for the great feedback!
12 years 7 months ago #3228 by Robert G
Hey Olivier,
The problem isn't with your plugin. It's an ordering issue. I was having trouble with slideshowCK not displaying and after many hours of fiddling thought to reorder the system cache plugin so that it loads after the jQueryEasy plugin. Guess what? Now the slideshow works just fine, I don't get anymore 404 emails, and the site loads faster. Plus, I'm still using JCH_optimize.
Robert
12 years 7 months ago #3231 by admin
Thank you so much Robert for the feedback! I do appreciate it.
Glad you found out the issue here.
