file Conflict in Sobipro. Need Help
12 years 2 months ago #2463 by Kyleblun
Conflict in Sobipro. Need Help was created by Kyleblun
I am having a jquery conflict in Sobipro. This is what their support guys say
Hi Kyle, from some reason You still has JavaScript conflict:
TypeError: jQuery(...).rating is not a function
174.120.127.92/~figsterc/components/com_....jquery-1.8.1.min.js
Line 14
it looks like a modified library, do You have possibility to disable it loading?
My question is how can I sort this problem using jquery easy?
12 years 2 months ago #2466 by admin
Replied by admin on topic Re: Conflict in Sobipro. Need Help
if that library is really not needed, use the advanced setting in jQuery Easy: 'strip remaining scripts' (the code to include in that field is the path you find in the 'src' attribute of the 'script' tag).
