file Conflicts not fixed after using plugin
13 years 5 months ago #245 by Kyleblun
Conflicts not fixed after using plugin was created by Kyleblun
I was getting a conflict error on my site in IE. I installed jquery easy and enabled, but still getting the error. Can you suggest some tweaking I might need to do in the advanced config section or anything else that might help. Attached is a screen shot of the error.[url=http://http://www.figster.co.za/restaurant-guide/76-The-One]Link to my site[/url]
13 years 5 months ago #246 by admin
Replied by admin on topic Re: Conflicts not fixed after using plugin
I don't have any error as seen on your screenshot.
Do you still have jQuery enabled and set a jQuery version in the jQuery Easy plugin? There is no sign of the plugin being used when I look at your source code.
You do have several versions of jQuery loaded on your page...
13 years 5 months ago #247 by Kyleblun
Replied by Kyleblun on topic Re: Conflicts not fixed after using plugin
Sorry, I disabled the plugin earlier because I was trying some other options. I have enabled the plugin again. Appreciate any advice on how to kill the errors.
13 years 5 months ago #248 by admin
Thank you, I am on it right now.
You need to put
www.figster.co.za/media/sobipro/css/jque...hness/smoothness.css
into the remaining CSS to get rid of it and select 'smoothness' as the jQuery UI skin into the plugin.
Use 'script' instead of 'script declaration' for no conflict code.
That is what I would suggest for now.
13 years 5 months ago #249 by Kyleblun
Please excuse my ignorance. When you say "You need to put
into the remaining CSS." How do I do this.
13 years 5 months ago #250 by Kyleblun
Sorry. Ignore my previous reply. I understand that I must select "smoothness" as the theme to do so.
