file Dropdown swMenu dont work
12 years 2 months ago #2447 by admin
Re: Dropdown swMenu dont work was created by admin
Hello again, make sure that the menu module's script works with the version of jQuery you have set up in jQuery Easy.
In the plugin, you also have the option to see a report of what has been modified by the plugin (look into the advanced options). You will be able to see if the plugin has removed code that should actually be kept.
