exclamation-circle Slider disabled on front end when jquery is enable
12 years 3 months ago #2309 by byblacks
We installed jquery easy to resolve issues we were having with the Ohanah events application.
It fixed the Ohanah issues with the calendar and adding events from the front end, and caused a major error of stopping the slider on our websites home page.
The ohanah Tech support team say that modal.js is causing this errors.
Do you have a fix for this??
12 years 3 months ago #2310 by admin
there is really no way to tell without seeing the code.
Please post the URL of a page where you get this issue so I can look at it. Thank you.
12 years 3 months ago #2311 by byblacks
12 years 3 months ago #2314 by admin
I can see quite a few jQuery libraries loaded (3), which is way too many. I suspect one is loaded from K2 (you can disable it from K2 settings) and you may find a way to disable one of the 2 remaining ones.
You may be able to resolve your issues with jQuery without the plugin by removing the 2 extra libraries. Give it a try!
