file No changes
12 years 3 months ago #2301 by sk
No changes was created by sk
I installed the plugin on 2 different joomla sites and it´s activated and the latest in ordering.
Then I tried to change a lot of it´s parameters. But the only thing I get, is the message (in jQuery Easy Modifications Report): No changes!
And everything I do has no affect on frontend.
What is wrong?
12 years 3 months ago #2302 by admin
Replied by admin on topic Re: No changes
I don't think there is anything wrong, it probably is just a configuration issue. What is the report saying? Have you set the jQuery version to use? If you don't, just the minimum of changes are made (like stripping of blank lines).
12 years 3 months ago #2303 by sk
Replied by sk on topic Re: No changes
after I`ve tried some more things, I got it working.
So thank for you for your fast answer and for the plugin.
Regards
12 years 3 months ago #2304 by admin
Great! You are welcome.
