file Help please Jquery Conflict Joomla, Linelab OPC
12 years 3 months ago #2256 by target4fun
I have a rocket theme template and was told I had some conflicts.
What is going on is when I click the add to cart button on website when it redirects to next page the item didnt add to cart and it shows empty.
I have LineLab One page checkout and paypal advanced plugin
concealedhandgunonline.com/index.php/click-here-to-start-now
I have been stuck for over 6 hours on trying to figure this out and completely stuck. I downloaded plugin and enabled but didnt put local paths as I couldnt find them?
Any help would be appreciated with a donation and review! I just need some help getting this running and its beyond my ability.
12 years 3 months ago #2258 by admin
It seems like your site is working properly with the jQuery Easy plugin set up as it is. Items are added to the cart correctly. I have tested on Firefox successfully.
You do not need to use local paths (if you meant the jQuery ones), the ones from Google were added by default.
I have glanced over your code and everything seems in order.
