file exclude a plugin from jquery easy
12 years 4 months ago #2183 by mtruffa
exclude a plugin from jquery easy was created by mtruffa
is it possible to exclude a entire joomla plugin from jquery. I have a plugin DT register that does not function correctly with jquery easy enabled. it works fine with it disabled. If I disable JQE then the we template does not work. Any Suggestions.
12 years 4 months ago #2185 by admin
Replied by admin on topic Re: exclude a plugin from jquery easy
no, you cannot exclude a plugin when using jQuery Easy. What you can try is re-order the plugins in the Joomla! console.
What problem is occurring when both are working together? It would probably be better to try and resolve the problem at the source, resolve conflict instead of avoiding it. And that would probably benefit others. Any details? Thanks.
