file How to start?
12 years 4 months ago #2150 by dounne
How to start? was created by dounne
I have a [url=http//www.liberton.es]website[/url] running under Joomla 3 just for tests and I was looking for a Jquery solution.
I installed your plugin and activated it but, even after reading the docs (I promise), I can not make it work. I am a newbie and there is a lot of things I do not manage very well.
Looking at the source code I think Joomla is loading some *.js files ... and for another part, when I use HTML code with the TinyEditor, it automatically put some advise message :
// <![CDATA[
$("#tabs").tab();
Is this a conflict with such Mootool?
What should I do ? As said before it is only a website for test purposes so if you need access, no problem at all ...
Thank you very much !
12 years 4 months ago - 12 years 4 months ago #2151 by admin
Replied by admin on topic Re: How to start?
yes, indeed, that code is conflicting with MooTools.
There is nothing more you can do with jQuery Easy right now, it is setup alright with the default settings as far as I can tell.
You need to use jQuery("#tabs").tab(); for the jQuery code to work here. '$' is reserved for MooTools.
Actually, the best way would be for you to include the jQuery code in a 'document ready' syntax.
You will find plenty of information on my website talking about this subject (in the developer's section).
Good luck!
Last edit: 12 years 4 months ago by admin.
12 years 4 months ago #2152 by dounne
Replied by dounne on topic Re: How to start?
Thank you so much for your fast answer ...
Are you actually telling me the solution for Joomla 3 would be to link/"attach" some file with the information of the jquery version needed?
So I would need to upload it to my server and then link it for each article .. or in the index.php would be enough?
thank you again !
12 years 4 months ago #2153 by admin
I am not saying anything of the sort :-)
I am just advising you to add the code you have for jQuery in :
jQuery(document).ready(function($) {
    $("#tabs").tab();
to avoid MooTools conflicts.
