file [SOLVED] How to use joker * for {ena,disa}bling?
13 years 1 week ago - 13 years 1 week ago #2041 by lliseil
Started testing the new feature in jQuery Easy v1.4.2, i.e. the joker "*" for enabling/disabling the plugin by a path chunk. Actualy I was really looking for this feature.
Joomla 2.5.9 with SEO activated (Apache mod_rewrite)
VirtueMart 2.0 (SEO activated)
jQuery Easy 1.4.2 (jQuery + jQuery UI respectively via Google and local; Add No conflict Code: No*)
Say I want to disable the plugin for all pages starting in mysite.com/directory
Have tried to add "/directory*" then "/directory*" in 'Disable In Pages', but none works. That is whether in Virtuemart related pages or in the Joomla-only pages that start with this path. The plugin acts there like in the other pages.
Now I might use it the wrong way as documentation is still light on it. Note that I'm looking like I do with Apache mod_rewrite "joker".
Please let me know if you can eventualy add some sort of guidance.
EDIT: solved www.simplifyyourweb.com/index.php/forum/...h-and-joker-for-path
Last edit: 13 years 1 week ago by lliseil. Reason: solved
13 years 1 week ago #2043 by lliseil
OK my bad.
But errr, the Help file is from February and v1.4.2 is from yesterday
Also changelog says that we can add a joker '*' before or after a path for enabling/disabling the plugin on specific pages. It appears that it works before and after as long as you put it before ;)
That being said I just tested and the joker works brilliantly ;)
13 years 1 week ago #2045 by admin
Hello again,
you did it the right way, I have just noticed that my bug fix was not complete, I apologise.
I am working on a fix (of the fix, arghhh!!) right now. Please send an email to [email protected] and I will send you a version to try out. Please specify which version of Joomla! you are using.
Thank you for your patience.
13 years 1 week ago - 13 years 1 week ago #2046 by admin
No, it is my fault, the documentation is just not 'clear' enough. I will update it by the next version.
I am still going to issue an update because it is easier to understand that:
*/product will include all pages ending with /product
/product* will include all pages starting with /product
*/product* will include all pages containing /product
than having
*/product that includes all pages containing /product
(some cases are left out)
My BIG issue with previous users will be problems with backward compatibility.
In the meantime, I removed the changelog so users don't get confused.
Last edit: 13 years 1 week ago by admin.
The following user(s) said Thank You: lliseil
