file How to Set Plugin for Google Maps Autocomplete...
13 years 1 week ago #2024 by pippopippo99
Yesterday I tried to configure on my website this maps: jsfiddle.net/pbbhH/442/
that to make it work requires the installation of a jquery plugin.
I don't succeed to configure plugin at the best for run this maps.
The internal page of my website is: www.labottegadelweb.net/index.php?option...orm=contattiperprove
(see the field address that should be an autocomplete field address like a first link).
Thank you very much in advance.
13 years 1 week ago #2026 by admin
you cannot use the code as it is, Joomla! 'thinks' that '$' is meant for MooTools.
So $(function(){ is interpreted as MooTools, not jQuery.
I would suggest you replace it with
jQuery(document).ready(function($) { ... }
to separate the MooTools code from the jQuery code.
13 years 1 week ago #2027 by admin
You probably would need to use jQuery Easy to help you out, as you have several jQuery.noConflict() instances. Only one is needed.
13 years 1 week ago #2030 by pippopippo99
Hi, i would like to use your plugin for run this google maps :
but i activate the plugin and set jquery_noconflict option but the maps don't show.
Have an idea ?
13 years 1 week ago #2032 by admin
I suspect you have not seen my previous messages...
13 years 1 week ago #2033 by pippopippo99
ok then I do not understand what you mean practically
