file Many Jqueries that creates conflicts
13 years 1 week ago #2017 by ToroLoco
Replied by ToroLoco on topic Re: Many Jqueries that creates conflicts
I have tried what you mention below, but still there is no change.
If you check below links you will see that the template is corrupted in the first case. On the second the photos from kunena Forum don't open on lightbox windows.
Link 1
LInk 2
13 years 1 week ago #2018 by admin
Replied by admin on topic Re: Many Jqueries that creates conflicts
I am sorry but I am not seeing the changes I have suggested you do. And jQuery Easy is not enabled. The pages look exactly the same as before.
I also noticed one library is loaded twice:
www.e-camping.gr/components/com_community/assets/script-1.2.js
www.e-camping.gr/components/com_communit...ts/script-1.2.min.js
This is the same code.
13 years 1 week ago #2021 by ToroLoco
I am disabling the JQuery plugin because my first page is not loading, it returns this message
Fatal error: Maximum execution time of 30 seconds exceeded in /usr/www/users/encamp/ecamping/newsite/plugins/system/jqueryeasy/jqueryeasy.php on line 500
I have strip the code from sizzle and renamed it, but still the problems persist. Now I have the JQuery plugin enabled, but except frontpage since only there I have above problem.
Thx
13 years 1 week ago #2028 by admin
How did you disable the plugin in the frontpage? There are multiple errors. The right way to disable the plugin in the frontpage is to go in the advanced options of the plugin and add '/' in the 'disable in pages' parameter.
13 years 1 week ago #2029 by admin
I am not sure you need jQuery UI enabled in the plugin.
13 years 1 week ago #2031 by admin
For the contact page, I would suggest you disable all 'extra' modules (animations) and enable them one by one to see which one causes errors.
The sizzle file you renamed is missing, you will need to find where the previous file was called so it is included in the template again. Or add it manually in the template.
