file Conflict between Jquery Easy and RSS
13 years 6 months ago #214 by Bobses
Replied by Bobses on topic Re: Conflict between Jquery Easy and RSS
Well, I disabled Jquery Easy on my test site (is disabled on my live site too).
I apologize for the delayed responses, but I just came home from work. And tomorrow is another day... :)
13 years 6 months ago #215 by admin
Replied by admin on topic Re: Conflict between Jquery Easy and RSS
Thank you for turning it off. It is no problem, really :-)
13 years 6 months ago #216 by admin
Well, I have looked over the code again and again and I cannot understand what is going on here. I really don't have enough information to go any further. There is something conflicting with jQuery Easy that prevents it to go into its 'afterRender' function. As far as I can tell, you actually don't need the plugin, especially if you are getting rid of cdscriptegrator. I am putting an update to the plugin out real soon that gives much more flexibility and could even get rid of the cdcriptegrator code.
I would suggest you update the plugin when it comes out and if it does not work for you then, I am sorry to say you will be one of the few cases where this plugin won't be able to help you.
13 years 6 months ago #217 by Bobses
Thanks anyway, admin. I'll install the update.
13 years 6 months ago #235 by admin
I think I have nailed what the problem is in your case.
Can I use your email address (the one you registered with) to send you a beta version of jQuery Easy to see if that actually fixes it?
13 years 6 months ago #238 by Bobses
Yes, please, send me the new version of this plugin on my e-mail address.
Thank you.
