file Leading slash added
12 years 6 months ago #1794 by glendalerugby
Leading slash added was created by glendalerugby
Today I upgraded my Joomla (from 2.5.1 to 2.5.9) and then jQuery Easy. After the upgrade, jQuery wasn't loading. I noticed in the source code that the jQE scripts added a leading slash:
<script src="/https://ajax.googleapis.com ...
<script src="//plugins/system/jqueryeasy ...
I ended up adding the scripts without a leading slash manually in the index file. Do you know why this might have happened?
Thanks,
Michael
12 years 6 months ago #1795 by admin
Replied by admin on topic Re: Leading slash added
Hi Michael,
sorry, I have no idea why it did that, especially for an external link like the one from Google. This could be a problem with the Joomla! configuration... Weird that this happened after an update from 2.5.1 to 2.5.9, although there were significant changes from one version to the next. You should take a look at the release fixes and additions, you probably would get a hint from that.
12 years 5 months ago #1999 by admin
Hello Michael,
I have worked on the same issue with another user and I think I have found the cause of this problem. I do not know if you gave up on using the plugin or not (I suspect you did), but I will issue a bug fix soon, as soon as I have done more testing. In a nutshell: the plugin correctly creates paths but does not correctly replace the old ones in some cases (depends on server configuration).
