question-circle Image selector not working
12 years 6 months ago #1780 by mmmkz86
Image selector not working was created by mmmkz86
hi
i've used the jQuery easy on my website to reduce the conflict of jquery codes used by my website template ( from google cdn ) and other plugins
jQuery easy worked great but i have a little problem :
when i enable plugin , image selector in article submission in frontend not working
i cant select images
url : www.anarphotography.com
please help me
12 years 6 months ago #1781 by admin
Replied by admin on topic Re: Image selector not working
I will get back to you as soon as I return from a trip tomorrow. Thank you for your patience!
12 years 6 months ago #1782 by admin
I do not have access to this part of your website, but I could suggest that you disable the plugin when in edit mode (check the documentation on how to do so by using the 'disable in pages' advanced option). You probably have a conflict with MooTools. Make sure you did not disable MooTools with the plugin first!
12 years 6 months ago #1787 by mmmkz86
Replied by mmmkz86 on topic Re: Image selector not working
hi
thanks for your helpful reply
i just resolved the problem by reading the docs
thanks in advanced
:D
12 years 6 months ago #1788 by admin
You are welcome!
