file JQuery UI
12 years 6 months ago #1711 by SFMichael
JQuery UI was created by SFMichael
Plugin shows: The jQuery UI version of Joomla! could not be determined (v1.8.23 most likely)
Doesn't add script to any pages when enabled
12 years 6 months ago #1714 by admin
Replied by admin on topic Re: JQuery UI
this is just an info telling you that Joomla! does not have jQuery UI loaded in the administration console and therefore wa not able to check its version.
What are your settings? What are you trying to do?
12 years 6 months ago #1716 by SFMichael
Replied by SFMichael on topic Re: JQuery UI
Am simply trying to enable jQuery UI for use in my front end. It works when i set jQuery UI version to v1.8 however setting it to 1.9 tells me its cannot find it.
I can achieve what i want with v1.8, so currently not an issue for me.
Thanks :D
12 years 6 months ago #1719 by admin
The problem you are having is that Google stopped using generic versions of jQuery UI. Starting version 1.9, you need to specify the sub-version number on top of it. I have mentioned it in the documentation and on the site.
Latest jQuery UI 1.8 will work by itself, Latest jQuery UI 1.9 will work with the sub-version set up. I know, confusing...
The following user(s) said Thank You: SFMichael
12 years 6 months ago #1734 by SFMichael
Apologises missed that, thanks for your help!
12 years 6 months ago #1737 by admin
No problem :-), was easy to miss and you are not the first one. I have tried to make it more obvious in yesterday's build.
