file Disable By Component
12 years 6 months ago #1699 by rabel316
Disable By Component was created by rabel316
First off - great plugin! Thank you for your work.
I'm having a problem with MijoShop (OpenCart) and the plugin though. It's preventing some scripts from loading properly - is there anyway to disable jQuery Easy by component?
12 years 6 months ago #1702 by admin
Replied by admin on topic Re: Disable By Component
First of all, thanks for the compliment.
Unfortunately, this is not available at this time. I am adding it to the list of requests though for further review. There could be a test to see if a component is present on the page (although not necessary easy to determine that)...
12 years 6 months ago #1703 by rabel316
Replied by rabel316 on topic Re: Disable By Component
Thanks for the response! I used the disable by page commands to get rid of it as much as possible so for now it's ok. Looking forward to a potential update...keep up the great work!
12 years 6 months ago #1704 by admin
