file Trying to prevent multiple jquery libraries
12 years 7 months ago #1607 by mhornbuckle
Trying to prevent multiple jquery libraries was created by mhornbuckle
I have your plugin, but I am not sure if it is working properly. Any suggestions?
www.grnonline.com
12 years 7 months ago #1608 by admin
I took a quick look in the source code and everything seems fine. You may not need jQuery UI, take it off if you do not know if you need it. Is there anything that is not working that I should look at?
12 years 7 months ago #1609 by mhornbuckle
Replied by mhornbuckle on topic Re: Trying to prevent multiple jquery libraries
I appreciate the quick response. I have a Yoo Theme Widgetkit not working on the front page. They said it is due to the multiple jquery libraries, and configuring your plugin, the code seems cleaned up, but it is still not working.
12 years 7 months ago #1611 by admin
You should try and compare the source code with and without jQuery Easy enabled to see what changes occurred. Also, you can use the report settings of the plugin to see what changes have been made. If you selected 'remove MooTools', please un-select it. Also do not add jQuery 'no conflict' code from the plugin, it is already added by your template.
