file jQuery Easy not working
12 years 7 months ago #1552 by DaleWyngaard
jQuery Easy not working was created by DaleWyngaard
Hi Support team,
Just wondering if I could get some with the jQuery Easy, I've installed it correctly and it is working, but the problem is that it's not actually doing what it says.
I have two jQuery modules and depending on the settings of the jQuery Easy (Settings set to either: none or jQuery) respectively, then only one module will work correctly at a time.
I am using the following jQuery modules:
www.csslab.cl/ejemplos/timelinr/latest/horizontal.html
and:
joomquery.com/en/joomla/joomla-extension...s-joomla-module.html
Those two modules does not want to work together.
Please help if you can
I tried emailing you but that does not seem to go through.
Thanks,
Dale
12 years 7 months ago #1554 by admin
Replied by admin on topic Re: jQuery Easy not working
there may be some extra things to do on top of enabling jQuery Easy, depending on how the modules behave and have been 'constructed'. In order to help you out in setting jQuery Easy, I need to see your URL page to understand what conflicts. Could you post your live URL? Thank you.
