file Not rocking and rolling..
13 years 6 months ago #137 by yummy
Not rocking and rolling.. was created by yummy
Hi there,
I have installed your plugin and pretty much tried everything since over a day and so far I have not managed to get the jquery sliders I have installed to work.
Staging server:
htpp://frutaflora.com/joomla
Template: rocketheme mercado
Various jquery sliders:
Austin Slideshow
INow Slider
I have include more details in the attached text file.
Hopefully the solution is simple.
Thank you very much.
13 years 6 months ago - 13 years 6 months ago #138 by admin
Replied by admin on topic Re: Not rocking and rolling..
The problem comes from the fact that the jQuery library paths are not correct (extra /joomla in the path) and therefore the jQuery libraries are not loaded.
I don't know your server configuration and I suspect you use the extra path to test your website before going 'live'.
I would suggest you add the jQuery library paths by hand in your template for testing purposes. Keep jQuery Easy plugin enabled for the code cleanup. Test your scripts using jQuery. Once ready to go live (I am guessing without the extra /joomla path), take out your code added by hand and let the jQuery Easy plugin take over.
That should do it.
Last edit: 13 years 6 months ago by admin.
13 years 6 months ago #139 by admin
Well, stupid me: if you keep jQuery Easy enabled, it will also clean the code added by hand...
13 years 6 months ago #237 by admin
The upcoming release of jQuery Easy (v1.1.0) is actually going to address your issue.
