file Problem with help
12 years 9 months ago #1365 by actlogic
Problem with help was created by actlogic
I enabled the jQueryEasy plugin with the help enabled as the example in simplifyyourweb.com download page. After that I cannot see anything in the admin section of joomla. Anything but a light blue background with these:
jQuery Easy Modifications Report
No changes
Execution time (in seconds): 0.000200986862183
12 years 9 months ago #1366 by admin
Replied by admin on topic Re: Problem with help
could you send me a screenshot showing the problem?
In order to get the admin console back, you need to disable the plugin from the database.
Please refer to the documentation page 5 that explains the process. When you enable the jQuery Easy plugin again, please do not set jQuery for the backend until we understand why the report shows but overrides the console in your case.
