exclamation-circle pbm with internet explorer
12 years 9 months ago #1341 by regiscrea
pbm with internet explorer was created by regiscrea
I had a problem using a slideshow (slideshow ck) with sobipro, i solved this problem using jquery easy plugin -very good!! :) - now it work fine but the slideshow doesn't appear anymore on internet explorer, as i don't really know how to configurate jquery plugin, i would like to know what should i do so that the slideshow also appear on IE, can i manage it by configurate jquery plugins parameters? how? Or do i have to solve it directly on the slideshow?? thanks for all your help, your plugin have already done a lot!!
12 years 9 months ago #1343 by admin
Replied by admin on topic Re: pbm with internet explorer
if your slideshow is working in some browsers and not in others, it is almost certainly a problem of CSS compatibility.
JQuery Easy does not re-arrange or cleans up CSS or javascript depending on the browser. Make sure the slideshow works on its own with IE before hand. Also make sure IE-specific scripts have not been removed by the plugin (if there was any prior to using it).
