question-circle MobileJoomla
13 years 4 months ago #1346 by admin
Replied by admin on topic Re: MobileJoomla
Thank you for your input into this discussion.
I will look into adding an option to use the plugin in a select number of templates.
13 years 2 weeks ago #1961 by mccomb
Replied by mccomb on topic Re: MobileJoomla
I'm having the exact same problem with the MobileJoomla Elegance theme. I have JQueryEasy set to load on specific pages, like / but do not want it to load on the mobile version of the site as it's loading after JQuery Mobile and causing problems.
Is this code that was posted still the best way to deal with this problem?
From: if (JFactory::getDocument()->getType() !== 'html')
To: if (JFactory::getDocument()->getType() !== 'html' || defined('_MJ'))
Thanks.
13 years 2 weeks ago #1963 by admin
Yes, the plugin does not yet handle multiple templates. I am afraid you will have to solve it manually at this point.
13 years 4 days ago - 13 years 4 days ago #2069 by admin
Version v1.5.0 of the plugin is around the corner and will address the multiple templates issue. It will be an experimental feature and I am not certain it will address the MobileJoomla themes, I do not know how is handled the switching of templates in this case. It will certainly work with standard Joomla! template styles, though. Please try the new version and let me know what is missing for your special cases. Thank you!
Last edit: 13 years 4 days ago by admin.
12 years 7 months ago #3117 by jjhorta
Replied by jjhorta on topic Re: MobileJoomla
Anyone has a solution for this?
trying also to have a premium template (flat) working with jquery easy and it does not
jomsocial2.carmeetic.com
Thanks,
Joao
12 years 7 months ago #3118 by admin
Hi Joao,
please explain what is your issue, thank you!
