exclamation-circle chosen.jquery.js stripped out by JQueryEasy plugin
12 years 9 months ago #1306 by tommyfiddler
When trying to use the harvesthq.github.com/chosen/ jquery plugin I noticed that the javascript file get filtered out by jqueryeasy plugin.
The reason is that the chosen plugin file is chosen.jquery.min.js (or chosen.jquery.js) and the JQueryEasy plugin filter it out (Look at jqueryeasy.php line 532) because it think that this is a version of jquery.
As a workaround I am going to change the name of the file, but maybe there is another option as I lost quite a while looking for this issue.
p.s. Thanks for the JQueryEasy plugin, its great !
-Tom
12 years 9 months ago #1307 by admin
Hi Tom,
you can use a workaround... The plugin does think that the file chosen.jquery.js is a jQuery library and honestly, I need to keep the plugin this way or it will start misbehaving for others and stop removing the jQuery libraries that need to be removed.
In you case, I would just add that 'chosen...' library to the field 'Add script' in the advanced options. It will add the script after having removed it... Not perfect, but it will work and you won't have to change any name.
12 years 9 months ago #1308 by admin
And it will put the library at the right place...
