file Re: Explanation...
12 years 10 months ago #1123 by ezi
Re: Explanation... was created by ezi
hi there,
i installed the extension and nothing changed. the main issue on my site is the date picker doesn't open and in multi file uploader in contact form now its not possible to upload more then 1 file. there is a possibility for you to have a look?
right4u.co.il
thank you in advance for your help
12 years 10 months ago #1131 by admin
Replied by admin on topic Re: Explanation...
the plugin cannot help you because you probably have a MooTools issue and not a jQuery one. jQuery is not installed on your site and does not seem to be used by any component (unless I am not looking at the right page, in which case tell me where I should look). Sorry, but I cannot be of much help in this case...
