file No seeing the desired results.
12 years 10 months ago #1083 by manicred
Replied by manicred on topic Re: No seeing the desired results.
Sense I dont have that component installed, can you tell me what file I need to edit in order to insert the code you mentioned?
I now have smilies working!!
12 years 10 months ago #1084 by admin
Replied by admin on topic Re: No seeing the desired results.
Great for the smilies!
I have no idea where that code is at, it is not a library, it is a free form script. I would guess it is in the template folder (dd_redcar_05) because the nivo slider is used by the template (in /js/jquery.nivo.slider.pack.js). Or maybe even hard coded in your index.php file from the template.
12 years 10 months ago #1085 by manicred
Thanks for everything so far. I have scanned all the files for this template and the only place I can find that slider is in the index file. But I edited it and still no fix. I have attached the original file.
Would you mind seeing if this is the correct file to edit?
index.php
12 years 10 months ago #1086 by admin
there is no attachment here.
Please contact me at [email protected] to follow up on the issue. Thanks!
