file Double title
11 years 10 months ago #3660 by Xaman
Replied by Xaman on topic Double title
admin wrote: Try and override:
.item-page h2:first-of-type { display:none }
By doing:
.item-page h2:first-of-type { display:block !important }
Seems to have worked! Thanks. :)
11 years 10 months ago #3661 by Xaman
By doing:
Nevermind, it does work but it also brings back the double title. :(
11 years 10 months ago #3662 by Xaman
Ok, I found a fix, I went to the related news plugin and changed the title from h2 to h3 and now it shows.
But it would be nice to have a solution if I want to use h2 on the title.
11 years 10 months ago #3663 by admin
Replied by admin on topic Double title
The problem is that no solution can fit all...
It depends mostly on the template used.
The plugin is supposed to work on a standard Joomla page, but many times it is not good enough, like in your case.
