file http or https
13 years 4 weeks ago #760 by BooDoo
http or https was created by BooDoo
Hi there,
Firstly thanks for such an amazing plugin. It sorted out my problem with the Simple Image Gallery which stopped my CSS menus working on the T3 gantry framework.
I am very much a newbie, and was wondering if I should select HTTP or HTTPS for the front end? I do not have a ssl certificate website and it is just HTTP. Should I therefore be selecting HTTP over the default HTTPS?
Thanks in advance
13 years 4 weeks ago #761 by admin
Replied by admin on topic Re: http or https
Thank you for using jQuery Easy.
You can leave the default https selection, I believe it does not make any difference using http or https versions of jQuery if your site only handles http requests. This option becomes critical for people using the https requests for their site.
