file jquery mootools conflict
13 years 1 month ago #699 by admin
Replied by admin on topic Re: jquery mootools conflict
The problem you are having does not seem to be with jQuery but with MooTools. There are 3 calls to the libraries.
The jQuery Easy plugin won't help you with that.
The module 'menumatic' loads MooTools, check if you could disable MooTools in this extension. Also check your template for duplicate javascript lines.
